Clarity on the C81CFPE2 – Para Military 2 Carbon Fiber CPM 154/CPM S90V
tazkristi
Spyderco Moderator
Moderator
There has been a lot of spirited discussion about our latest Para Military 2 Sprint Run. I’d like to provide some clarity.
First, the basics.
The blade:
Spyderco is the first production company to use this unique and very exotic, composite blade steel from Crucible Industries of New York. The manufacturing process is in itself unique. It begins with a 1-inch thick plate of CPM S90V. The plate is placed in a specially engineered and built steel can and the voided areas on either side of the plate are filled with CPM 154 powder. The can is positioned on a vibratory table to ensure consistent density in the packing of the powder and then it is welded shut and subjected to a vacuum to evacuate any oxygen. The can then enters an autoclave under extreme heat and pressure where the powder forge-welds with the plate. Afterwards, the can is machined off; the remaining slab is cogged-down in a roller into flattened sheets suitable for making knife blades. Where many layered steels are produced by heating plates and then sandwiching the steels together, this process uses specialized equipment and welding techniques commonly featured in the manufacture of aircraft parts where steels are held to rigorous specifications to avoid structural failure.
The blade is ground full-flat, and additional surface jimping is machined on both the spine and the forefinger choil. A line marks the juncture where the two composite steels meet, giving each blade its own unique pattern that is the result of the homogeneous transition of two extraordinary modern powdered metals.
The handle scales:
Peel-ply Carbon Fiber
The MSRP:
$469.95 Our formula for pricing is based upon true cost and very small margins. We don’t price anything at what we think the market will bear.
Next, I’ll tackle many of the questions/speculation that has come up.
We set out to make approximately 300 C81CFPE2. The number was based solely upon the amount of steel we had at the time. Did we know we’d get more steel? Yes, but the lead-time for steel is longer than most people think. Particularly when you consider it’s a new, exotic steel composite. There’s also lead time for all the other materials that go into building a knife.
Knowing that we would ultimately obtain more CPM 154/CPM S90V composite we planned to use the future stock in other models. We knew that the Para Military2 would be a great choice for the first-ever offering. We also knew that to release a small quantity now and then release more later would have consequences. Historically speaking, we’ve been down that road before and it was a less-than-friendly journey. We make it a habit to listen to our customers (you) and we learned from that journey.
The small quantity was a reasonable test for us to determine what it would take to work with CPM 154/CPM S90V composite. I don’t know how many of you remember the first time we worked with pure CPM S90V, but there was a wicked learning curve and numerous adjustments that had to be made from a production perspective.
Did we know that such a limited run would be highly collectable? Of course we did, that’s why it’s available to the members of the Collectors Club. Given the commitment that our CC members make, shouldn’t they, every once in a while, receive something that is truly collectable?
Why did we choose the Para Military2? Honestly, there are a LOT of factors that go into that decision. It’s not just about the popularity of the model. Some of the factors include working it in to an already packed production schedule. Our goal was to get this new composite steel manufactured into an unbelievable knife. But that goal had to be balanced with real-world production challenges as well as the challenge of not knowing what it would be like in production. No one had done it before.
If we held of, announced a Sprint of say 1200 or more, and then ran into production delays… well you all know how that story goes. We’ve been there too.
There will be other models produced with CPM 154/ CPM S90V composite steel. There will be real-world testing to come in the future.
This wasn’t about addressing the situation with “flippers” and the Mule Team (or any other limited run).
Spyderco does not have a “Board”. Our company culture is very much so the opposite of “Corporate”. We try, very hard, every day to do business in a fair, proper and honest way. Our mindset is not about how much can we get. It’s usually more along the lines of “it’s never been done before… how can we do it.”
Could we have done a better job of releasing more information about this one knife? Yes, yes we could have. I can’t explain it, I can’t give you an excuse for it. I’ll just offer our apology for not making an announcement sooner.
We promise, there was no conspiracy on this one. Just a crew pushing forward through the next challenge.
We do appreciate your passion and your commitment to Spyderco. We value each of you.
Thanks much!
Taz,
Thanks for sharing this information with the community!! I know this one will be hard to get but, glad to hear of & looking forward to the future offerings.
Thank you for your forthrightness and information. Sounds like it was a worthy challenge. It's also great that more such composite blades are coming.
Any chance for a picture of the blade? Curious to see the weld joint, shades and overall looks.
Is this the first composite blade for Spyderco? Is the blade manufactured by Spyderco or Crucible?
Thanks. Your email confirms the confidence many of us had in Spyderco and all of you who make the company the place it is.
Wow what'a great way to test a brand new, super high performance steel than by releasing 300, nearly $500 knives to people who are threw and threw collectors, not users... :(
Before I get attacked for this yes I do applaud spyderco's translucence in the matter and their honesty, but does this at all seem the best way to test a new steel they are bragging about? The mule team is one thing, even a PM2 sprint, but is a super rare, extremely limited, only sold to CC members run of 300 going to accomplish any sort of end-user steel testing? Absolutely not. These are going to be locked away to appreciate in value, not used...
Wow what's great way to test a brand new, super high performance steel than by releasing 300, nearly $500 knives to people who are threw and threw collectors, not users... :(
You read that they didn't have the steel to make more, right? I don't see anything wrong with rewarding the members of the Collectors Club, as they are the first to show support for Spyderco through such an onerous commitment (btw, I'm not a member of the CC). Besides, new releases with the same steel will come, just be a little patient. They'll probably be cheaper, too.
Edited to add: From the way I read Kristi's post, the idea is for Spyderco to test production with this steel. In other words, users will have the ability to test the steel once Spyderco irons out all the kinks that may appear during the first releases.
Openness and transparency is appreciated from the fine folks at Spyderco.good knives people and company. Thanks
Definitely appreciate the transparent explanation. Thanks for letting us "in the know" therefore as to not breed speculation, like some other companies might by keeping us in the dark.
Instead of whining and moaning about it why don't you become a CC member, then you will get the next "super rare, extremely limited, only sold to CC members run of 300(fill in the blank) whatever knife" and then you can do your own test on said knife .
I'm not a CC member but I think its great they are doing this for them.:thumbup::cool:
I wish every company had the decency and ethics of Spyderco. The great thing is that Spyderco produces a lot of variety of high quality knives. There are a lot to chose from that are available. It can be frustrating not getting "the one", but after buying knives for years I remain confident that there will always be another "one" and I can't afford them all anyway :) Patience and persistence will satisfy many/most ELUs over the long run. No reason at all to feel that bad about missing out occasionally!
And thanks for the explanation, Kristi. Very decent of you/spyderco to even put it out there.
I am not going to "attack" you even though you were a bit brash. Consider though that Spyderco does not produce new steels just for us to test them. The mules are a simple way to figure out how to heat treat and grind a new steel, and analyze the steels potential for future use. This first run will serve its purpose of Spyderco figuring out how to manufacture this steel for future runs. They already know how S90V performs, this is not about a new steel and how it performs, but it is about taking on a new manufacturing challenge. Spyderco could throw away every piece they make and accomplish the exact same goal, but decided with such a limited supply of steel initially, they would take care of their most die hard fans and collectors. I wish I had the money to be a CC member, but I don't. Am I bummed I probably won't ever even get my hands on one? Sure, but I am not mad about it. I will say that I seriously doubt they are bragging about it and that is completely out of line in terms of constructive criticism.
Sign me up.
Can someone post a link for the collectors club enrollment?
FWIW, there are only 200 slots in the Collectors Club and, AFAIK, not all are filled, so not all will wind up in the hands of collectors. As for the other, with no offense meant to Spyderco, aside from laminates that use damascus as the outer layers, I'm not sure what this, or any other laminate brings to the table for 99% of users, aside from wavy "hamon-like" line on the blade which, if history is any indicator, serves mostly to give nit-pickers one more thing to whine about when it's not exactly the same on both sides.
Agreed, in spite of some very erudite posts by Ed Schempp and others a year ago about this steel, the advantages were neither very obvious nor compelling to me from a user's perspective. On the other hand, lots of innovations probably start that way.
I'm a big Spyderco fan, and I don't have any problem with the company releasing this new steel to collectors. And I much appreciate Tazkristi cluing us in about the issues that went into the decision.
But what I don't get is what kind of performance gain this new composite will offer to actual users. Does the cpm 154 make the blade significantly tougher? The edge will still be S90V, so chipping of the edge should not be affected. Is there an issue with people breaking the blades of S90V?
Collectors just collect anything that is different, whether it makes for a better knife or not. But for those of us looking for performance gains, what can we expect?
Kristi, while we're on the subject of PM2's, will be there be any sprints coming soon for the common man to actually be able to get? We may be less deserving than our CC counterparts but we have been waiting for something special as well. The original goes for astronomical numbers on the flipper market, so there's probably an audience for a CF PM2 down the road? How's the fluted CF coming along? Will that be for the CC collectors and dealers only also?
Wow, that is way cooler than the "composite" construction I was thinking of. I've changed my mind. Now I would like one please.
